Roseann
[SOLVED] NO DATA CONNECTION
Wed Mar 21, 2018 12:54 am
Since i purchased my phone in December, i have not been able to access data on my phone. I have tried my sim card in other phones and the data works fine. However, once i put it back into the Blackview8000 i am not receiving any. PLEASE HELP!!!!!
Re: NO DATA CONNECTION
Wed Mar 21, 2018 9:22 am
Hi there!
First you have to contact your phone carrier to get your correct APN settings, wich you have to set.
Then enable your data connection and everything will work.
Roseann
Re: [SOLVED] NO DATA CONNECTION
Sat Mar 31, 2018 2:03 pm
I have already contacted my service provider and have already entered the correct APN settings however i am yet to access my data.
Mon Apr 09, 2018 12:12 pm
Just to know it, where are you from? In wich country are you using your device?
