Thu Apr 19, 2018 6:45 pm
Not sure if this thread is still going.
But anyways:
Admin: What "dudas" is trying to say, is that he/she is trying to get a guarantee that the cell phone will arrive. And if there is any problem, who can be contacted to fix it? Is there a technicall Support? Is the only way to buy is via Online Shops like Aliexpress? Or is there a physicall shop that he/she can buy from?
It's probably the first time "dudas' is buying a blackview so it raises concerns.
@dudas,
Desculpe. Mi espanol no es muy bueno, pero creo que vas a entender.
Yo compre via AliExpress y no tuve ningum problema. Creo que por AliExpress o otros shopping onlines es la unica manera de comprar.
No hay una garantia en verdad, pero, se tuber qualquier problema pode hablar con el vendedor y pedir un nuevo o ayuda.
En este forum, intentamos ayudar a todos con problemas o dudas normalmente en ingles. Pero se deses pode hablar en espanol y yo intento ayudar.
@Admin,
I just explained to "dudas" that he can buy via AliExpress and other online shops. There is no physical shops outside China as I see. And we are here to help.
Thanks,
George SPiT
(BV9000PRO / BV8000PRO / BV6000)
