bonx49
touchscreen problem
Mon Mar 19, 2018 10:35 am
i replaced my bv8000 pro by a bv 9000 pro FHD and i have a problem: navigation bar is not working !!! make reset and flash ... but the problem persist .
Re: touchscreen problem
Mon Mar 26, 2018 8:57 am
hello,
have you tried to get into the recovery mode to reset the whole system and settings?
bonx49
Mon Mar 26, 2018 10:24 am
Yes try all : recovery, reset, flash, nothing works... I'm technicien from another brand... Seem to be touchpad defect...
Mon Mar 26, 2018 10:54 am
ok.
i've known your problem here. i had reported to the tech support team.
please wait for our reply.
i will reply you before 28th March.
thx.
Wed Mar 28, 2018 2:02 am
what is the version of your phone?
did the problem come out suddenly?
or did you disassemble your phone before?
bonx49
Thu Mar 29, 2018 9:55 am
no disassembly
problem was always here
BV9000PRO FHD VO 20180104
Thu Mar 29, 2018 10:20 am
what is your firmware version?
bonx49
Tue Apr 03, 2018 8:19 am
VO 20180104
