CrazyWolf74
[SOLVED] CHARGE ISSUE
Fri Mar 16, 2018 2:20 pm
Since few weeks I have a problem when charging my phone..
The USB-C works only on one of the two sides.. I've tried with other cables which work with my brother's BV8000..
Nothing seems damaged on the phone..
I've tried to flash a clean version (20180124) but same result..
What can I do ?
Regards
Re: CHARGE ISSUE
Sat Mar 17, 2018 9:59 am
CrazyWolf74 wrote:
What can I do ?
Regards
Did such issue happen just after a firmware update or suddenly? It looks like an hardware fault!
CrazyWolf74
Re: CHARGE ISSUE
Mon Mar 19, 2018 7:48 am
It's not linked to a firmware upgrade.. Yes it looks like an hardware fault.. What can I do ? I don't have any reparation center in my area...
Regards
Neville
Re: CHARGE ISSUE
Mon Mar 19, 2018 8:29 am
CrazyWolf74 wrote:
Regards
You'll need to purchase a new charging board on Aliexpress, and install it yourself. Admin will probably be able to find the post on this board that has the link to the part and the teardown video. The part is only around US$12.
Re: CHARGE ISSUE
Mon Mar 19, 2018 8:37 am
CrazyWolf74 wrote:
Regards
Did you try to gently clean the USB-C port? It may be dirty.
If cleaning it can't solve your issue, as Neville says, you can try to replace the usb charging board by yourself, but remember that you may void your warranty with your seller. If you don't want to risk, or if you're not handy enough, consider contacting your seller to have your device replaced under warranty.
If you want to replace it by yourself, let me know and i'll post what you need here.
CrazyWolf74
Re: CHARGE ISSUE
Mon Mar 19, 2018 9:53 am
The USB port is clean.
Thanks Neville for your answer but I don't want to void my warranty...
I will contact again my seller to replace my phone.
Re: CHARGE ISSUE
Mon Mar 19, 2018 2:53 pm
it is the best (and only) choice for your specific case.
Users browsing this forum: No registered users and 10 guests
