jonilson
Wifi keep disconnect and connecting.
Fri Mar 16, 2018 1:53 pm
The wifi connection on this phone isn't good since I turned on at the first time. Today the wifi begin to disconnecting and connecting all the time. I am just using the 4G connection, it's impossible use the wifi connection and I search in the internet about that and discorver that it's a commom problem in this phone. Has no solution in anywhere. I will put this cellphone in the trash and bought a new that works.
Re: Wifi keep disconnect and connecting.
Thu Mar 29, 2018 7:30 am
hello,
What's your current firmware version?
have you tried to enter the factory mode to reset your phone?
if not ,here is the guide link:
viewtopic.php?f=192&t=334922
jonilson
Thu Mar 29, 2018 3:18 pm
My firmware is updated, S8_Blackview_V1.0_20171102(1201), in accordance with the latest version of firmware.
I already try reset the phone to factory mode, but it isn't work.
Sun Apr 22, 2018 10:36 am
Will forward such details to our tech team for a fix! ;)
