Official ROMS of P6000
Fri Mar 16, 2018 10:03 am
Bagaiya
Re: Official ROMS of P6000
Tue Jun 05, 2018 2:31 pm
please how do i install this update because the version i am using currently is V0.1-20171021
Wed Jun 06, 2018 2:09 pm
You can follow this tutorial, it will work in the same way ;)
viewtopic.php?f=192&t=319505
cachiporra
Mon Aug 20, 2018 10:43 am
Hi!
I am a new owner of this P6000.
I received it last Friday, August 17 and I immediately started the task of flashing the ROM.
I tried it for several hours until, finally, I got it after detecting some small error in the process for our P6000:
- On STEP 4, point 5, "Press phone's volume-up-key while connecting it (powered off) to your Computer. Use original cable" while in the P6000 you have to do "Press phone's VOLUME-DOWN-KEY while connecting it.........".
- On point 7, the same error, we have to press VOLUME-DOWN-KEY while connecting it to the Computer.
Thank you very much (users and collaborators of the forum) for the tutorial and help!
Mon Aug 20, 2018 11:17 pm
Thanks for your feedback ;)
Bagaiya
Sun Sep 30, 2018 1:05 am
Please I need to know if there is any significant difference between version V0.1-20171021 and the new version 200180104.
Sun Sep 30, 2018 1:30 am
It carries some minor fix. If you want you can avoid it.
cachiporra
Sat Oct 06, 2018 7:45 am
Hi!
I made a factory reset because the problems I reported in other post.
Now, my P6000 is back in V0.1-20171021 version and it seems that runs better. Some old problems of my phone persist (screen not good, proximity sensor not good, and other), at momment (1 week) no random restart (touching wood I am...), but the battery is clearly more durable. With the use I make, 200180104 runs only 2 days. 20171021 runs 3 days.
I would not install 200180104 version.
Mon Oct 08, 2018 11:07 pm
cachiporra wrote:
Hi!
If your phone, for you, works without issues, there's no need to update it ;)
Kadim7
Sun Nov 22, 2020 3:01 am
Hello, where can I download the native firmware
V0.1-20171021?
Big request, answer my mail andrej.kadimov@yandex.ua
