kavedel
[SOLVED] problem with apn
Wed Mar 14, 2018 1:31 pm
rvj13 wrote:
I have a blackview bv8000pro for 2 months and since 2 days the one triggers the camera in burst mode, it is 40 photos automatically several times to follow until saturate the card sd.
impossible for me use my phone !
Probably your button stays pressed because there is something between your photo button and the metal side panel holding it there. Try to remove the side panel and clean it.
rvj13
camera that goes off alone + reboot issue
Wed Mar 14, 2018 8:50 pm
hello
I bought last December a blackview phone bv8000pro. After only 3 months of use, it has serious operating problems that are as follows:
-hot photos 40 burst and this several times to follow and several times in the day for no reason while the phone can be placed on a table for example.
-stopping and restarting without reason of the phone several times in the day
-blocking of the phone, obligation to restart it
-imposability to send or receive text messages
Re: camera that goes off alone + reboot issue
Thu Mar 15, 2018 9:03 am
rvj13 wrote:
hello
I closed your previous thread, as you opened this one.
For the first problem, maybe Kavedel is right. Your photo button may be stuck.
For the other issues, i reccomend to update your device to the latest firmware version and after that perform a factory reset and report back.
