jman0
Menu button behaviour on 20180308
Tue Mar 13, 2018 4:22 pm
I just flashed the new 20180308 version, via SP Flash Tool, and I did factory reset afterwards, and have noticed that the menu button has gone back to its previous behaviour, from many updates ago.
Now, if I want to access recent apps, I have to double tap on the button, and a long press will trigger the menu. Is anyone having this issue?
Since I don't have any reboots, and the translation issues are not big enough to be that annoying, I'm back to 20180124.
Regards.
Re: Menu button problem on 20180308
Tue Mar 13, 2018 8:41 pm
Thanks for your feedback Jman0!
chidkaii
Sat Mar 31, 2018 5:15 pm
I think this is a very good news for me because one tab and show menu its not have benefit for me.
AleP
Recent Apps Button
Tue May 01, 2018 10:22 am
After the last OTA update shown in the figure the bug of the recent app button has not been resolved yet you have to double click the button to show the recent apps, this will be solved in Android 8 or in a future update?
Thanks
