herve63
[SOLVED] application for wifi call
Tue Mar 13, 2018 11:50 am
is there an application or an update for wifi calls for the BV8000.
thank you
Re: application for wifi call
Tue Mar 13, 2018 3:59 pm
Built-in WIFI calls are actually not supported, and you have to consider that these should be also supported by phone carriers (not all of them support this feature!).
But in the end you can use 3rd party apps (Skype and so on..) without any issues.
