tony37420
[SOLVED] BV 8000 PRO problem with camera and network
Mon Mar 12, 2018 2:53 pm
I made the change of the block stops because my speaker was disrespectful as well as the front block because the speaker was defective. The phone starts perfectly. There are 2 problems:
1) The photos of my BV8000 pro are blurred on the middle, the focus is not done. You have to tap or shake it to get it in focus.
2) The phone network gets lost sometimes, but the wifi and data connection works.
What can I do ? :)
thank you very much :D
Tony
Re: BV 8000 PRO problem with camera and network
Mon Mar 12, 2018 5:33 pm
Hi there! ;)
1) What's your firmware version?
2) I suggest to check the antenna cable, it could be misplaced (i'm telling you that because you have already opened your device to replace some modules, and antenna cable may have been misplaced because of that)
tony37420
Mon Mar 12, 2018 11:46 pm
blackview_admin wrote:
Hi there! ;)
My firm version is : V0.1_20170803
I have replug the wire of the antenna, but the problem stay.
I can use data connexion without problem, but I can't call.
An idea ? :)
Thank's
Tue Mar 13, 2018 8:56 am
Your firmware is definitely OLD! ;)
Please update your device to the latest version (20180308), perform a factory reset and report back if your issues get solved.
tony37420
Tue Mar 13, 2018 9:12 am
I have doing today a factory reset, but the phone said : "the phone is up to date", how to have the update 2018?
Thank's
tony37420
Tue Mar 13, 2018 9:47 am
Sorry I read a new information , version on my phone : V0.1_20170803_20180105-1104
Tue Mar 13, 2018 3:54 pm
I suggest you to try to update your device again, the 20180105 version is also old.
If you can't get the newest one (20180308) i suggest to flash your device to it.
ROM download:
viewtopic.php?f=192&t=213272
Flashing tutorial:
viewtopic.php?f=192&t=319505
tony37420
Wed Mar 14, 2018 9:49 am
ROM download:
Flashing tutorial:
Ok, I download only : "BV8000Pro_blackview_20180308" and I flash the phone with the application wrote in the tutorial
Yesterday I have transfert the "BV8000Pro_blackview_20180308" on my phone and I have doing a local update, 1 hour later it's done, the probleme is always stay
Wed Mar 14, 2018 10:13 am
Did you perform a factory reset after such update?
tony37420
Wed Mar 14, 2018 10:58 am
Oh no, you think it's necessary?
Users browsing this forum: Google Adsense [Bot] and 5 guests
