  • 1
  • 2
  • 3
  • 4
  • 5
  • 8
JiullJuinn
[TRACKED, WORKAROUND FOUND] Pin Code Changed By Itself
Sun Mar 11, 2018 9:49 am
Hi. Second time Pin code changed by itself and I cant enter phone. And Clock show current time with big delay.
Re: Pin Code Changed By Itself
Sun Mar 11, 2018 3:32 pm
Hi there!
It's the first time i hear about such issue.
Please update your device to the latest firmware (20180124), perform a factory reset and report back ;)
carl.g
Re: [SOLVED] Pin Code Changed By Itself
Wed Apr 11, 2018 6:46 am
This also seems to have happened to my phone today. Have used it several months, then suddenly does not accept PIN.
Have data on it that I do not want to wipe.
Please advise...
Wed Apr 11, 2018 5:01 pm
Please advise...
Can you unlock it with fingerprint?
carl.g
Wed Apr 11, 2018 7:44 pm
Cannot unlock with fingerprint. That stopped working too. No response when I try.
Thu Apr 12, 2018 5:47 pm
I can't see any other solution except a factory reset, unfortunately.
Motionman2008
Fri Apr 13, 2018 9:06 am
I did some searching around and I found something that's meant to use Google's "Find my Device".
In order to do it, you'll need to go to https://www.google.com/android/find and log in to your connected google account. When it finds your phone, choose the lock option and it should prompt you to put in a new password.
This is meant to override the current password when set (after some delay ~5mins)
Sat Apr 14, 2018 11:15 am
Thanks for your precious feedback!
This solution may work, so... let's hope that! ;)
ipollen
Mon Apr 16, 2018 12:04 pm
My phone has also just changed it's PIN and I can no longer access the phone.
I normally use finger print access and every once in awhile it will also prompt me for the PIN.
This had been working for many months prior to lunchtime today.
Help :-(
Mon Apr 16, 2018 2:21 pm
Help :-(
Just read the posts above ;)
  • 1
  • 2
  • 3
  • 4
  • 5
  • 8
