MasterOfPuppers
Wanting to buy a Blackview phone
Sat Mar 10, 2018 3:25 pm
So as the title says, i would like to buy a phone from Blackview. Can you recommend me a resistant one. I've been looking at Blackview BV8000 Pro because a friend of mine has one but his only complaint was that the audio/headphone jack is too long for any normal headphones so he had to buy wireless headphones. He also told me that only a few BV8000's have this kind of problem. Is this true ? Should i risk getting the BV8000 ?
Re: Wanting to buy a Blackview phone
Sat Mar 10, 2018 10:24 pm
Hi there!
Choose the rugged phone you like more, Blackview made them all tough ;)
The BV8000 Pro is a great device, and is equipped -by design- with a deeper than standard headphones and usb ports.
Don't worry about it: the device comes with it's own cables and if you want you can easily buy adapters to use normal cables.
When buying your device, be sure to choose a trusted seller (i.e. Amazon) wich will surely honor warranty without any issues ;)
jman0
Mon Mar 12, 2018 9:14 am
You can find jack adapters on Aliexpress and Amazon. There's a specific thread on the issue on this forum
