inzone
BV9000 loudspeaker problems
Fri Mar 09, 2018 4:03 am
I have a new BV9000 that has "out of box" a faulty hands free microphone. Please advise how I can purchase a replacement as I get no response when using the Contact form on your website.
Re: BV9000 microphone problems
Fri Mar 30, 2018 10:00 am
hello,
you can purchase it on the platform like Aliexpress.
hope it can help.
thx.
inzone
Fri Apr 06, 2018 1:12 am
Can you be more specific as to where I might purchase a replacement microphone, as not of the vendor I have contacted on Aliexpress can supply?
Re: BV9000 loudspeaker problems
Sat Apr 14, 2018 12:04 pm
You can find it here:
https://www.aliexpress.com/item/Origina ... autifyAB=0
Unfortunately i can't find a single speaker replacement... but you can get it from the link above.
inzone
Sat Apr 21, 2018 6:59 am
I am not looking for a speaker, I want a microphone. Can you please advise where I can get one from? The phone is under warranty so you should be able to provide one.
Sun Apr 22, 2018 1:01 am
Our official Aliexpress store should be able to help you properly. Please contact it.
https://blackview.aliexpress.com/store/ ... 47a0Qbxf4J
Please remember that for warranty you'll have to contact your seller ;)
inzone
Tue Apr 24, 2018 6:38 am
Unfortunately the seller does not respond to requests for warranty service, so your suggestion is unhelpful.
Tue Apr 24, 2018 8:43 am
Sad to read that, very bad seller, definitely.
inzone
Wed Apr 25, 2018 2:48 am
Thank you fopr your feigned sympathy. What are you going to do to help me obtain the parts needed to fix this phone under warranty?
Wed Apr 25, 2018 8:29 am
As i posted before, feel free to contact OUR official Aliexpress store, wich will surely help you properly:
