Rexi
[SOLVED] Sound problem - phone mute
Thu Mar 08, 2018 7:55 am
I have serious issue with my phone. Sometimes it suddenly muted by itself and I can't set the volume up, only rebooting is the solution. Not every sounds are muted: only the ringtone, alarm, notification sounds but screen lock/unlock sound is works.
Re: Sound problem - phone mute
Thu Mar 08, 2018 8:27 pm
Hi there!
Unfortunately your issue is definitely uncommon and not reproducible.
Considering that, I suggest you to update your device to the latest firmware (20180124) and after that perform a factory reset.
If this can't solve your issue, it may be related to an hardware fault. In this case i reccomend you to contact your seller for a replacement under warranty.
Rexi
Re: [SOLVED] Sound problem - phone mute
Thu Mar 08, 2018 9:04 pm
There is the latest firmware on the phone (20180124) and I made a factory reset but later than I installed the update. After updating (but before the factory reset) the problem occurred more often. The phone is never totally mute just some kind of sounds are missing (but vibrating function always works)
My previous phone was a BV6000 with the same problem... I need to look for another brand I think.
Thu Mar 08, 2018 9:36 pm
Sorry but i can't understand: did you perform a factory reset after the update?
Rexi
Fri Mar 09, 2018 9:44 pm
Yes I did, but not right after installing the firmware update just a few weeks later. Anyway this method is annoying a little bit... Why can't do the firmware update via OTA? And without spend time to save and restore my personal data?
Sat Mar 10, 2018 11:58 am
OTA updates may be tricky, they don't reach every user and sometimes may behave in an odd way, expecially if not followed by a factory reset.
