ayirus89
[SOLVED] Mobile suddenly switched off & not booting
Mon Mar 05, 2018 12:14 pm
My mobile suddenly switched off while using. SOS few other apps opened automatically & suddenly crashed & not booting. Tried to restart. Stuck with Blackview & android logo & this screen is running every 2 mins.
RED notification LED is blinking repeatedly.
Pls help.
Re: Mobile suddenly switched off & not booting
Mon Mar 05, 2018 10:08 pm
Here you talked about a flashing related problem....
viewtopic.php?f=192&t=360904
What are you doing?
ayirus89
Tue Mar 06, 2018 4:23 am
What are you doing?
I am looking for a reason why it happened.
Tue Mar 06, 2018 9:37 am
What are you doing?
Was bad flashing cause or consequence of the issue you posted here?
Please give use more details if you want to be helped properly.
ayirus89
Tue Mar 06, 2018 11:19 am
What are you doing?
I flashed to see whether it's software issues.
It was working normally. It suddenly having issues with mic & then suddenly apps opened & never turned on. I used usual apps.
P.S I have flashed my mobiles 100 times before. This is not the first time.
Tue Mar 06, 2018 4:16 pm
As i stated in the other topic, if flashing a new firmware and performing a factory reset can't solve your issue, there's nothing more to do apart from contacting your seller to get your device replaced under warranty. :(
ayirus89
Wed Mar 07, 2018 3:07 am
I am from India. Will they replace? Will you b able to recommend them to do the same as the company representative?
Wed Mar 07, 2018 11:41 am
Unfortunately not. You'll have to talk with your seller, we can't do anything else.
