lucianop
[SOLVED] Flash Firmware don't apply new firmware
Sun Mar 04, 2018 8:19 am
Hi have 20170803 version but when I flash latest version everythings reports OK (DL OK - PASS) but when phone reboots and I check for firmware version, it is same version, 20170803.
I've looked at flashing guide PDF for instructions.
Can you help me?
Thanks.
Re: Flash Firmware don't apply new firmware
Sun Mar 04, 2018 11:33 am
Hi there!
If flashing went as it should, this can't be possibile.
If you go to Settings -> Firmware update you'll find your actual version showed as: BV8000Pro-Blackview-V0.1_20170803_XXXXXXX where "XXXXXXX" is your real actual version. Please check that and report back ;)
lucianop
Re: [SOLVED] Flash Firmware don't apply new firmware
Sun Mar 04, 2018 1:28 pm
Yes, it works!
thanks.
Sun Mar 04, 2018 4:51 pm
Great! ;)
