ner68
[SOLVED] Whatsapp and e-mail Notifications
Fri Mar 02, 2018 12:38 pm
I don't received any whatsapp or e-mail notification until I specifically enter to the application so notifications appears.
I tried to change battery optimization Settings -> Battery Optimization -> Whataspp ; and Whatsapp Battery Uptimization Not Optimize.
Also I tried Settings -> Battery Optimization -> " 3 Dots" and only appear Reset app preferences
I don't know what to change to received whatsapp or e-mail notification when they're send so I don't need to enter every time to the app to see if there's any.
Re: Whatsapp and e-mail Notifications
Fri Mar 02, 2018 12:57 pm
First, what's your firmware version?
ner68
Fri Mar 02, 2018 2:36 pm
Kernel Version 4.4.15
root@android#14 Thu Aug 3 15:09:38 CST 2017
Build number
BV8000Pro_Blackview-V0.120170803
If not info requested please tell where I can find
Fri Mar 02, 2018 8:13 pm
Build number
Go to "Settings" -> "Infos" -> "Firmware update" and report back your actual version.
Sebi
Sat Mar 03, 2018 6:29 am
I have exactly the same problems,since the last update.
BV8000Pro-Blackview-V0.1_20170803_20180105-1104
This is the version i have installed.
I also tried a factory reset.
Any ideas would be great.
Sat Mar 03, 2018 9:45 am
Your firmware version carries a known bug concerning the "background task clear" setting. Refer to this thread:
viewtopic.php?f=191&t=345022
I suggest you to update your device to the latest firmware version (20180124) and then perform a factory reset.
Be sure to whitelist your messaging or email client in the "Background task clear" setting and everything will work smoothly! ;)
ner68
Sat Mar 03, 2018 5:21 pm
I could not find any "infos" at Settings however at
Settings --> About Phone --> Wireless Update I found
BV8000Pro-Blackview-V0.1_20170803_20180105_1104
I press the buttom Check for Updates and says Your device's software is currently up to date
Also in a reply you mention a whitelist, I don't know what it is and I don't no where to find it.
Please if I need something to do, detailed step by step, I see some other post where it is mention how to update firmware and I don't undersatand how to do it.
ner68
Sat Mar 03, 2018 5:31 pm
Also you mention some Background Task Clear and I can´t find any where nor the Button "on" and "off". Neither a factory reset that is mention in some other posts.
Please very clear with you answear.
Step by Step
Thanks.
Sun Mar 04, 2018 12:07 am
As happened to user Sebi, your firmware version carries a known bug concerning the "background task clear" settings.
I reccomend to flash your device to the latest firmware (20180124) and then perform a factory reset.
Firmware download:
viewtopic.php?f=192&t=213272
Flashing tutorial:
viewtopic.php?f=192&t=319505
How to perform a factory reset:
viewtopic.php?f=192&t=334922
After that go to Settings -> Background task clear. Now enable it and put a check near Whatsapp and your email client.
Then go to Settings -> Battery. Now disable intellingent power saving and disable battery optimization for Whatsapp and your email client.
Now your device will work flawlessly!
ner68
Re: [SOLVED] Whatsapp and e-mail Notifications
Mon Mar 05, 2018 11:39 am
In a reply you mention a whitelist, I don't know what it is and I don't no where to find it.
Also, there's a feature call Wireless update. Why don't just download the new firmware version there ?
It would been much easy for users.
