IfeBV
BV9000pro charging intermittently
Tue Feb 27, 2018 11:26 am
I have a BV9000pro that misbehaves when charging with the OEM charger. It connects and starts to charge with the RED LED indicator but after about 6 sec, it stops charging and starts again itself repeatedly.
I also tried using a BV8000pro Charger but got the same result. However if the TYPE C usb connector goes in a little bit without clicking in completely, it charges properly and continuously.
These two chargers works well with another BV8000pro.
SO anyone with similar experience and has solved it?
Re: BV9000pro charging intermittently
Wed Mar 28, 2018 8:44 am
it seems like a hardware problem.
maybe you can go to the phone store and check it.
if it works, please report to us .
thx.
