Paul
[SOLVED] How to create playlist with multi-addition or disable music native app
Tue Feb 27, 2018 8:08 am
Hello Blackview team member and Blackview community,
On the native music app, because I can't create playlist differently than adding one by one the titles, I would like to disable this native music app for another.
But when I go to Settings>Apps>All apps>Music> the icon "Disable" is inactive, it's greyed.
I have already did it for another apps like "messaging" (because of the limit of characters) and the icon "disabled" was available.
Do you know how to create playlist with multi-addition or how to disable native app ? please
Could you help me ?
Thanks in advance,
Best regards,
Mr. PAUL
Re: How to create playlist with multi-addition or disable music native app
Tue Feb 27, 2018 10:06 am
Hi there!
Native music app can't work in a different way: you'll have to add each track to your playlist one by one.
Disabling the native music app is not possibile as it is linked to many other system functions.
Just use another music app, you don't have to disable the native one for that. ;)
