Kryogenius
[SOLVED] BV8000Pro - 20170803_20180105-1104 - Alarms disappearance
Tue Feb 27, 2018 6:15 am
Build 20170803_20180105-1104
Since this build i have installed on bv8000pro,
I set up a daily alarm, active it. Do aynthing else, put the screen off by power or any other actions : the alarm still active in menu but inactive on time widget and it doesn't work to ring up on time set up previously.
I haved wipe cache and reset factory without any improvement of this.
Is someone has the same issue ?
Thanks
Kryogenius
Re: BV8000Pro - 20170803_20180105-1104 - Alarms disappearance
Tue Feb 27, 2018 10:17 am
Hi there!
Can you update your device to the latest firmware (20180124), perform a factory reset and report back? ;)
