asmoroth
[SOLVED] no 4G in Belgium provider Telenet
Sun Feb 25, 2018 6:36 pm
Dear
In Belgium we have a SIM card in which we are not able to use a 4G connection to surf on the internet. It is however possible to surf on 3G. Also the roaming option has to be enabled, otherwise it is not possible to surf.
The APN settings are not automatically detected, but when entered manually it is possible to surf under above mentioned conditions.
Below mentioned the settings:
APN: telenetwap.be
MCC: 206
MNC: 05
Verification type: PAP
APN type: default
There is only one PLMN code in the available networks PLMN ID: 20601
When opening this one it is not possible to tick 4G and save.
Any help would be greatly appreciated to enable this.
The device has been flashed with the latest firmware and factory resetted after the flash.
Re: no 4G in Belgium provider Telenet
Mon Feb 26, 2018 9:50 am
hello, we will check with our person soon, any news will back to you in time.
Mon Feb 26, 2018 1:56 pm
This should solve part of your problem.
viewtopic.php?f=191&t=328646
You'll have to ask your phone carrier about the correct APN settings.
Is your SIM working in 4G in other phones?
asmoroth
Mon Feb 26, 2018 5:57 pm
Dear those are there correct settings. Worked perfectly and automatically in the old phone. A Samsung phone.
Tue Feb 27, 2018 9:54 am
Did you check this link?
asmoroth
Sat Mar 03, 2018 11:21 am
I did. No solution.
Re: [SOLVED] no 4G in Belgium provider Telenet
Sat Mar 03, 2018 11:58 pm
Sorry but there's nothing more i can do to help you at the moment.
Your problem is related to your phone carrier's APN settings, you should check them with your phone carrier or try another carrier.
