amanguver
USB-C to 3.5mm audio jack cable
Sun Feb 25, 2018 4:04 pm
Hi!
Recently, my usb c to audio cable stopped working and I need another one.
I noticed that the tip of this cable is slightly longer than a regular usb c cable so I can't buy a generic one.
Where can I buy that cable? Can I buy it directly from Blackview?
Re: USB-C to 3.5mm audio jack cable
Thu Mar 29, 2018 7:37 am
hello,
you can buy it on the platforms like Aliexpress.
Deslandes
Wed Apr 04, 2018 8:23 pm
my smartphone also has this, but I already bought new cables and nothing, already did a factory restoration and nothing! can you help me?
and that I have not even bought a month the mobile phone and thus I'm not satisfied
Sun Apr 22, 2018 10:39 am
What about using the OTG cable (wich came out of the box) together with an USB-3,5mm jack adapter? it should work flawlessly! ;)
I also suggest the way to a bluetooth headset, to definitely leave from cables, adapters and so on ;)
Deslandes
Mon May 21, 2018 5:42 pm
still does not work even with the factory cable, I have expensive headphones and wanted to use ... I'm busy!
Thu May 24, 2018 9:08 pm
Did you use the OTG cable with an USB-3,5jack adapter as stated in my previous post?
