Bluescorpie
Display rotate and mirroring
Fri Feb 23, 2018 1:19 pm
Please help. My display is error, rotate and flip mirror and blink too
Bluescorpie
Re: Display rotate and mirroring
Sun Mar 25, 2018 12:34 pm
@blackview admin
I have brought to service phone. This lcd problem..
Please any respond, we are your customer...
Very bad support
Mon Mar 26, 2018 3:17 am
Have reported your bug, will come back soon. Thank you for your waiting.
Mon Mar 26, 2018 3:25 am
Hello if anybody from other places have the same problem?
Mon Mar 26, 2018 3:58 am
Try to flash your phone, if the problem doesn't disappear, please keep contacting us.
Bluescorpie
Sun Apr 01, 2018 2:45 pm
I have many times to flash... There are not change anything
Fri Apr 20, 2018 8:11 am
Did you perform a proper factory reset? if yes, and the issue is still here, it looks like an hardware fault.
In this case, there's nothing more to do execpt contacting your seller to have the device replaced under warranty (if still running).
Bluescorpie
Sun Apr 22, 2018 1:32 pm
Yes the hardware problem,, it very shame, bad quality,
And the seller has not provided help to guarantee, online shop just it..
I have bv 6000 and bv 7000 pro, Good bye blackview, not anymore
Thu Apr 26, 2018 9:51 am
Unfortunately it's not our fault if your seller doens't honor warranty terms.... next time buy directly from our store or from a trusted store and you won't have issues like that anymore.
