pyrateoso
[SOLVED] BV800Pro Stuck in Safe mode
Thu Feb 22, 2018 9:31 pm
Microphone just stopped working for some apps(text voice and phone calls) however working for voice assist & internet search I reset phone...... now its stuck in safe mode........ phone is only 5 months old. Help!
Re: BV800Pro Stuck in Safe mode
Sat Feb 24, 2018 3:19 am
Hi there!
Please follow this tutorial to perform a factory reset:
viewtopic.php?f=192&t=334922
pyrateoso
Re: [SOLVED] BV800Pro Stuck in Safe mode
Tue Feb 27, 2018 2:40 pm
Correction phone is three months old! Completed factory reset. Microphone still not working and now it wont charge, still stuck in safe mode! :evil: :(
Tue Feb 27, 2018 4:33 pm
If a complete factory reset can't solve your issue, unfortunately there's nothing more we can do.
You'll have to contact your seller for a replacement under warrany.
ayirus89
Tue Mar 06, 2018 12:58 pm
My mobile also faced same problem. Tried flashing but no use.
But, @Admin how can it be mentioned as solved if the problem is not solved ?!
Tue Mar 06, 2018 4:21 pm
The issue has been marked as solved, even if, sadly, the only solution is to contact the seller to get the device replaced under warranty.
