nemesisfox
[SOLVED] FCC ID or TCB Certificate Radiation Tech Specs BV8000 PRO
Tue Feb 13, 2018 6:04 am
Good day
someone can help me with the fcc id for my bv 8000 pro, i need this information to use this phone on the network of my country,
thanks in advance
Re: fcc id from bv 8000 pro
Tue Feb 13, 2018 8:07 am
The information you need should be in attachment.
Also refer to this thread:
viewtopic.php?f=191&t=324950
LIFEFORCE
Thu Feb 22, 2018 8:29 pm
Dear Black View Community.
Im in Colombia and in here the cellphones must to be registered, in order to register this phone here we need the FCC ID or the TCB Certificate. I have been the last week trying contact Blackview to receive the FCC ID or any support to do it but I havent got any answer, today Im writting here is my last hope. Could you please provide me the FCC ID for the Blackview VB8000 PRO or could you officially register the phone at https://apps.fcc.gov/oetcf/eas/reports/ ... Search.cfm
Im looking forward to hearing about You soon! otherwise my phone could be blocked in 60 days.
Kind Regards and Thanks for your help!!
Re: FCC ID or TCB Certificate Radiation Tech Specs BV8000 PRO
Sat Feb 24, 2018 3:22 am
Take a look on the previous post, it may help!
LIFEFORCE
Re: [SOLVED] FCC ID or TCB Certificate Radiation Tech Specs BV8000 PRO
Wed Feb 28, 2018 10:32 pm
Thanks very much for the reply. Unfortunately that FCC doesn't have the normal format, (my cellphone operator told me is probably false) but I trust this company and recommend it very much. I would like to ask you to please try to make the FCC appear in the oficcial FCC website: https://apps.fcc.gov/oetcf/eas/reports/ ... Search.cfm
And if you can find the certificate of approval that appears after that.
The FCC id is an alphanumeric code in the picture is seen only a numeric code.
I'm looking forward to hearing from you soon!!
I have some weeks yet to register the phone before gets blocked...
Kind regards!
Thu Mar 01, 2018 10:16 am
Kind regards!
I just asked it to the engineering team. I hope that you'll get it soon!
Guache91
'Legal' issue with my phone
Mon Apr 09, 2018 9:36 pm
Hi there,
I can't proceed the registration of my phone where i stand without the FCC number.
I made some researches and i found the BV6000's code: https://fccid.io/2AKP6-BV6000 but not BV8000 pro.
Please help, it's a good phone which met all my expectations, it will be sad if they blocked it :cry:
Thank you!
Tue Apr 10, 2018 6:54 am
Unfortunately FCC ID is still not available at the moment. I'm sorry.
LIFEFORCE
Tue Apr 10, 2018 2:30 pm
Hi. My phone is about to be blocked in my country and nonuseful. Could you please provide all the documents you can about this phone. As certificates of radiation etc all what you can please. All the documents you can as specs, manuals, certificates, studies, etc all what you can have!! I will try to homologate it with it. And please can you tell me when the company can register a FCC id in the website I told you in past posts??? I appreciate any reply!! Please try to send complete documents!!! I'm looking forward to hearing from you soon!!!!
Guache91
Tue Apr 10, 2018 8:17 pm
:cry: :cry:
