inventor4fun
[SOVLED] Screen broken after falling from the pants
Wed Feb 21, 2018 2:26 pm
I bought the smartphone in June 2017, today the smartphone fell from the pocket of the pants and broke the screen.
Is it under warranty?
How can I fix it?
I live in Italy.
thank you.
ghost82
Re: Screen broken after falling from the pants
Wed Feb 21, 2018 3:41 pm
Hello, no it isn't!
Rugged phone doesn't mean the warranty covers damages from falls, immersions and similar things.
You can buy yourself the replacement parts, or ask to a local general mobile repair center to repair your phone (if it's able..).
Neville
Thu Feb 22, 2018 3:37 am
How can I fix it?
I live in Italy.
Easy to fix. Your warranty does not exist in any real sense but it doesn't matter as this is a simple repair.
Purchase a replacement screen IN FRAME (don't buy a cheaper screen with no frame)
https://www.aliexpress.com/item/Alesser-1920x1080-IPS-For-Blackview-BV8000-BV8000-Pro-LCD-Display-Touch-Screen-With-Frame-Digitizer-Assembly/32816389001.html
Undo the metal bracket holding the screen connection cable socket on the mainboard in place. Lift old screen cable connector up and put old screen to one side. Carefully push new screen connector into socket and make sure it goes in flush.
Screw metal bracket back in place. Push screen back into phone and tighten the screws (always be careful not to rip the gold cable during entire process or you will be up for another screen.)
On old screen there is a pin hole to push up the IP68 badge and sticker to transfer to new screen...and earpiece silver trim can be carefully prised up and stuck into new screen (remove sticker cover on new earpiece).
All done.
inventor4fun
Thu Feb 22, 2018 7:20 am
I ordered it now.
Thank you
Thu Feb 22, 2018 9:25 am
Neville is great as always! ;)
Ps. your device looks like it fell off many times, not only once! :lol:
