angusmg
WiFi not working
Tue Feb 20, 2018 8:04 pm
I have a problem with BV9000 HD+ with the wifi connection. After a few seconds it stops seeing any network. I tried full reinstall with sp flashtool, no luck. Could you give me some advice on how to fix it? Could it be a faulty baseband, or hw problem with the main board?
Thanks in advance.
Angus
Re: WiFi not working
Thu Mar 29, 2018 6:54 am
hello,]
What's your current firmware version?
you can try to enter the factory mode to reset the phone.
here is the guide link:
viewtopic.php?f=192&t=334922
