SNap92
[SOLVED] Headphones for BV8000
Tue Feb 20, 2018 7:47 pm
Hi all,
can someone please give me a link to either aliexpress or gearbest where I can buy headphones that fit the jack of my BV8000.
Please send a link that is in english since for some reason I cannot buy the headphones provided in this link: https://fr.aliexpress.com/item/Original ... 8fb51450f8
Re: Headphones for BV8000
Thu Feb 22, 2018 9:54 am
Hi there!
It was asked many many times, just read the forum and you'll find everything.
By the way, i suggest an adapter ;)
https://www.amazon.it/dp/B0786K1D6W/ref ... AbT020ZGR/
McDonald
Re: [SOLVED] Headphones for BV8000
Thu Feb 22, 2018 10:42 am
popkiller
Sat Mar 24, 2018 4:56 am
[SOLVED]
This worked for me. But it was not necessary to cut inside the jackhole. Just carefully cut the 3.5mm connector to the necessary size.
https://www.youtube.com/watch?v=GEyFid0 ... KKt4AaABAg
I recommend to cut a cheap adaptor instead of your headphones, because it's a bit risky. I'm very happy to be able to listen through my HQ AKAI Professional earphones again. Before, I tried a Bluetooth adaptor but it reduces audio quality and the battery lasted only 2 hrs. I also tried this one, but it doesn't fit BV8000 Pro: https://es.aliexpress.com/item/Used-Ori ... 0.0.XFCm7y
