michele.mignini
[SOLVED] URGENT! Compatible adapter for my phone (BV8000 PRO)
Tue Feb 13, 2018 10:31 am
it is a quite urgent issue.
Is anyone aware of a charger adapter which could work fine and it is available in the european market (germany)? My charger got lost and I need a replacement. The original charger from blackview is arriving in 4-6 weeks from now... But I immediately need something which could charge my phone. I cannot wait all this time.
I tried with other adapters from Samsung or Sony but they don't work.
Please give me some good news.
Thank you!
Michele
Ralf-BV
Re: URGENT! Compatible adapter for my phone (BV8000 PRO)
Tue Feb 13, 2018 12:53 pm
Still working: https://www.amazon.de/UGREEN-Ladeadapter-Wandladeger%C3%A4t-Intelligent-Technologie/dp/B00R25QZDC/ref=sr_1_27_sspa?ie=UTF8&qid=1518522417&sr=8-27-spons&keywords=ladeger%C3%A4t+blackview&psc=1 - but not fast. Just testet with BV8000pro
Not testet: https://www.amazon.de/UGREEN-Ladeadapter-Wandladeger%C3%A4t-Intelligent-Technologie/dp/B00R25QZDC/ref=sr_1_27_sspa?ie=UTF8&qid=1518522417&sr=8-27-spons&keywords=ladeger%C3%A4t+blackview&psc=1 - should be fast.
In any case its important to use a cable, that is working, some (not BV) doesn't at my BV6000. May be it´s the same at BV8000pro, where I only use original BV. An original Blackview cable is also avalable at Amazon.
Netsplitz
Tue Feb 13, 2018 1:06 pm
Any USB charger should charge the phone, but the USB cable is special... The connector is longer than normal. You can try find one with rubber material and cut away a millimeter to expose more connector.
Good luck
Tue Feb 13, 2018 8:17 pm
I quote what Neville said.
You can use EVERY charger (also if your charger will charge slowly compared to the original charger).
For the non-standard USB-C cable used by the BV8000pro, you can use a normal micro-usb cable coupled with the micro-usb/USB-C adapter provided with your phone.
michele.mignini
Re: [SOLVED] URGENT! Compatible adapter for my phone (BV8000 PRO)
Wed Feb 14, 2018 12:43 pm
Thank you everyone for the reply.
I still have the original cable. The only piece missing is the adapter. I have tried the adapters that I have but they don´t work. The red LED goes on, but the phone doesn´t charge.
I will now try the adapters that you suggested. Thanks again.
michele.mignini
Fri Feb 16, 2018 10:31 am
UPDATE: I have tried with another charger, which is supposed to be fast and also support the MTK PumpExpress Plus. The adapter is the Sony "UCH 12" and operates at three different voltages, 5, 9, 12. But I have the same problem as with the other chargers. The red LED goes on but the phone doesn't charge. After 40 minutes it is still 0%.
Funny enough, the phone charges (slowly) when I plug it to the usb port of my laptop... Isn't that weird?
If someone could give me an explanation for this before I buy other adapters, I would really appreciate that. Thanks a lot!
Fri Feb 16, 2018 11:16 am
Just for information... what's your firmware version?
michele.mignini
Fri Feb 16, 2018 5:53 pm
My ROM is 20180124. I had no charging issues with the original adapter.
Mike!
Sun Feb 18, 2018 12:28 pm
I never used the original adapter. I charge the phone with some Amazon adapter (5 V/1,8 A) without problems. I can also charge it with any of my power banks.
Perhaps your USB-C cable is defective? For example the one that came with my BV8000 Pro can't establish a stable data connection on PC. So I orderd another original cable on eBay and it works. However, charging works fine with the cable that came with the phone.
Sun Feb 18, 2018 3:41 pm
Exactly. That's why i also suggested him to use another micro-usb cable with the micro-usb/USB-C adapter provided with the device ;)
