tysken
[Solved] updates doesn´t work
Sun Feb 11, 2018 5:35 pm
Try to install it and nothing happens.
The file is 18-01-05 s670c-jk-bv9000-63-fhdp-cobom_128g48g_64g48g-bom14-n1_blackview-BV9000Pro-FHD-VO.6-20180104*******.rar
*=are your chinese signs i can´t wrote down.
I downloaded the update for the 9000pro trough Mega, renamed it to .zip(otherwise the local update can´t find the file.
Start the update, nothing happens .After reboot , the old version and no changes.
Can you check please?
Thanks
My version BV9000Pro_Blackview-V1.1_20171215_20171215-1716
My IMEI 355680090075342/355680090075359
Re: your updates doesn´t work
Mon Feb 12, 2018 2:54 pm
Sorry, this versions update may only work with updating over the air or by flashing.
Also the chinese signs have to be deleted from file-names on computers in other areas.
tysken
Re: [answered] local updates doesn´t work
Fri Apr 13, 2018 8:33 pm
i understand now why there are two different BV9000. the one with -F is FHD the other without.So the file can´t work on my, because its not -F.
Problem solved.
we can delete this so we save space and looks better.lol.
Re: [Solved] updates doesn´t work
Thu Apr 26, 2018 6:03 pm
Thanks for your feedback!
