lest
[Solved] declaration of conformity
Fri Feb 09, 2018 8:07 am
I need the declaration of conformity in the language German. if i dont get it i dont get my smartphone .
I hope you can help me fast because i have a time limit to get my bv9000pro.
if only englisch declaration of conformity exist , maybe translate with google translate?
thank you.
mfg lehnert
Ps: i cant contact per mail, always "mail failed to send"
Re: [Solved] declaration of conformity
Mon Feb 12, 2018 3:19 pm
This declaration is included in the user manual in your phones box (also in german).
lest
Tue Feb 13, 2018 11:33 am
thank you for the fas answer.
if its in the user manual i rly ask me why the zoll didnt see it :/ or its not enough either i dont know.
but now i have to make a objection against the "Zoll".
Can u pls send to: S_lehnert@gmx.de
a declaration of conformity for the bv9000pro?
or put here in a answer a download link?
thank you very much
Mfg S. Lehnert
Mon Feb 19, 2018 1:34 pm
I attached a photo. This is all I can do for you in the moment.
2018-02-19 14.31.36 (Large).jpg (510.37 KiB) Viewed 2371 times
