elrik1090
[SOLVED] Audio on USB type C
Fri Feb 09, 2018 2:25 am
Hello !
Is there a way to connect audio ( like headphone ) using type C - 3.5mm jack adaptator or the version of USB type C of the Bv8000 pro don't take audio ?
Thank you !
jman0
Re: Audio on USB type C
Fri Feb 09, 2018 7:16 am
elrik1090 wrote:
Hello !
Thank you !
I tried, but didn't work. The only way I succeded was using a tiny USB sound adapter from Aliexpress, connected through the USB host cable. It's this device, worth less than $1: https://es.aliexpress.com/item/2016-New ... 0.0.la71NN
Anyway, you can now also get 3.5mm long jack adapters on both Aliexpress and Amazon. There's a thread about it on this same forum.
Fri Feb 09, 2018 8:59 am
The bv8000pro's USB-C port is audio capable, but you'll need a longer headed USB-C adapter, as such port is deeper than a standard one.
elrik1090
Re: [SOLVED] Audio on USB type C
Fri Feb 09, 2018 3:34 pm
Ok thank you. I had try a USB C to 3.5mm adaptator that I had modified to be longer but doesn't work.
I never find good longer 3.5mm adaptator on Aliexpress..
Fri Feb 09, 2018 7:49 pm
Just search in our forum :)
viewtopic.php?f=191&t=168899&start=20
N_adio_n
Sun Feb 11, 2018 6:13 pm
I have the same problem. I bought the USB-C to a 3.5mm jack adapter. I cut the connector to the length of the original connector, but it does not work.
I want to make a car holder and use USB-C for charging and audio at same time. I have bought USB-C to USB-C and jack adapter. I can charge phone through the adapter, but audio still nothig.
Are you really sure the VB8000pro supports USB-C audio?
Do I have to set something up?
Sun Feb 11, 2018 11:23 pm
The original USBc-USB OTG adapter combined with a 3rd party USB-3,5mm adapter will work without any issues ;)
Rgaspar
Fri Oct 12, 2018 12:27 am
sorry re-open this topic but i have the same "issue"
the type c to 3,5mm jack that i have (original from my bv9000pro) doesn't work on my bv8000. on bv9000pro work flawless. does the bv8000 compatible with usb audio?
20180522-1555 firmware version
note: i´ve tryed different rom's inclusive oreo rom and the result was the same
Sat Oct 13, 2018 11:32 pm
The answer is in the post just above yours...
