BV9000 official ROM download links
Wed Feb 07, 2018 10:13 am
For BV9000 devices equipped with the new Full-HD+ display:
BV9000_FHD_blackview_V0.5_20180119  Android 7.1
Optimizes the Face Unlock (available at night), add the input method and toolbox.
https://mega.nz/#!HyBR1KbJ!auzoDS4uY9ne ... vzeYyxXgx0
BV9000-FHD-Blackview-V0.5-20180119
Also released via OTA. Made the device Google approved.
https://mega.nz/#!MTZRxZRZ!UFr_VpAfVK4B ... u-lUVDyxPE
For BV9000 devices equipped with an HD+ display:
BV9000_HD_Blackview-V0.9_20180120
https://mega.nz/#!UOgR1Cbb!HH4NqxB4D4PH ... XzW9FnS_Sw
stancorotax
Re: BV9000 official ROM download links
Wed Jun 19, 2019 9:53 am
Is it possible to upgrade a BV9000 HD+ (1440x720) with a new FullHD lcd and put the FHD ROM? Would it work or there is some other difference in the mainborard?
Thanks
Wed Jun 19, 2019 10:38 am
stancorotax wrote:
Thanks
Hi there, this is not recommended.
metall
Wed Oct 14, 2020 12:03 pm
I have a BV9000-Pro that has a firmware crash. even a full reset does not work. I decided to reflash the device, but I was faced with the fact that more than one firmware from your site is not installed. SPFlash Tools gives error 0xC0070004. I found a firmware somewhere on third-party sites that was installed, But the connection to the mobile network works very badly. Please give me a working firmware. The firmware was BV9000-PRO-RU with android 8.0
Thu Oct 15, 2020 4:09 am
Russia only has the Android 7 version, not the 8.0. you have to update it via this link:
https://mega.nz/#!l1oXCIoR!JDcL-woxfkGYP7PpSdwyNkdTaFBRP7pDtE5xVzWKvVk
metall
Sat Oct 17, 2020 6:53 am
Thanks. This is exactly what I needed. I suggest you fix the firmware in case someone else comes in handy.
For those who face the same problem: After the firmware, it was possible to restore IMEI only using the MauiMETA program.
