kavedel
[SOLVED] Repair flashlight
Wed Feb 07, 2018 5:30 am
How can I replace the flashlight that doesn't turn on?
Re: Repair flashlight
Wed Feb 07, 2018 9:50 am
You'll have to open your device (and maybe voiding your warranty).
A replacement flashlight can't be found on Aliexpress at this time, so i suggest to contact your seller or one of our global agents:
http://www.blackview.hk/global-agents/
kavedel
Wed Feb 07, 2018 7:54 pm
If I send the device to your agent here in Greece am I going to pay for the parts replaced or the warranty covers them and I will have to pay only for the work?
Wed Feb 07, 2018 11:22 pm
Warranrty usually gets covered by your seller, but you can ask them.
By the way the work won't be expensive ;)
kavedel
Re: [SOLVED] Repair flashlight
Fri Feb 09, 2018 10:40 am
I spoke with your agent here in Greece and they don't have spare parts for BV8000. Since I have already ordered the loudspeaker from Aliexpress to be replaced, I asked them if I can send them the parts and they can fix it and they said yes. The question is what do I need for the flashlight to be repaired? Is it just a connection problem that they can fix straight away or is there a need for a spare part? Can you please ask your technicians there about their opinion on the matter?
Thanks in advance
Fri Feb 09, 2018 2:36 pm
Thanks in advance
Nobody can tell you that before opening the device. You'll need to buy the flashlight module just to be sure.
kavedel
Fri Feb 09, 2018 2:54 pm
Any link to that?
Fri Feb 09, 2018 7:45 pm
kavedel wrote:
Any link to that?
Unfortunately not available :(
kavedel
Sat Mar 10, 2018 8:55 pm
I installed the new speaker yesterday and it works fine now but I couldn't reach to the flashlight to have a look because I should remove the mainboard of the phone and couldn't risk that without having at least a video showing how to do that, so I did nothing. Is there by any chance someone here having any instructions or a video link of complete disassembly of the phone?
Sun Mar 11, 2018 8:32 am
Nothing that i can easily find on Youtube :(
