Considering I have two hardware problems on my device after only a month of use without being responsible for any of them (phone didn't drop or got wet), I thought I should open a new thread for those with the same issues, so we can report all the hardware failures we came up against on this device and Blackview may consider to be more careful about their hardware or assembly department.
I must mention that firmware update to the latest version and factory reset is done with no effect on the problem.
So,
1) I have problem with the loudspeaker making distorted sounds and reduced volume making it hard to hear when ringing and unable to use for music
2) Led flashlight is not working any more by any way so forget about taking pictures at night
Both problems occurred after a month of use and not right out of the box.
