zwang
BV9000 PRO not work on AT&T network
Fri Feb 02, 2018 10:19 pm
I have a BV8000 PRO, it works fine on both AT&T and T-MOBILE network.
So I'm happy to upgrade it to BV9000 PRO, and I just got it today.
When I put my old SIM cards on BV9000 PRO, it can't find service on AT&T network. T-Mobile works fine though.
I don't know how to return it on TOMTOP, but I will try.
I do some search and and found this discussion, seems this is a common problem.
https://forum.xda-developers.com/androi ... r-t3739470
Please find a solution. Please!
Re: BV9000 PRO not work on AT&T network
Tue Apr 03, 2018 5:46 am
hello,
First you have to contact your phone carrier to get your correct APN settings, which you have to set.
Then enable your data connection and everything will work.
