EricNL
[SOLVED] Software update
Tue Jan 30, 2018 5:22 pm
I have a question about software update,
my blackview bv8000 turned on software version: SOLID_4G3-Blackview-V0.1_20170721_20170721-1132
(Not updated since I got the phone)
now I want to update the phone but says that it has the last version.
I assume that I should flash my phone to the last update, but can I update to: BV8000Pro_blackview_20180124 at once or do I have to do each update separately?
Kind regards,
Eric
Re: Software update
Tue Jan 30, 2018 5:25 pm
The latest update carries all the previous fixes, so just flash your device to the 20180124 version and enjoy it ;)
Remember to perform a factory reset after updating it!
EricNL
Re: [SOLVED] Software update
Tue Jan 30, 2018 5:33 pm
thank you for a quick response, I will update the phone tomorrow.
Kind regards,
Eric
grAwp
Wed Feb 07, 2018 9:26 am
Everything OK after update/flash and FR ?
EricNL
Sat Feb 24, 2018 5:11 pm
sorry for late response :shock:
Yes. it succeeded, only sometimes do report that camera no longer works. if I then restart the phone, it will work again.
the phone works great for the rest :mrgreen:
