burg3r
[SOLVED] Bluetooth LE Support after update
Sat Jan 27, 2018 10:10 am
After the last Firmware Update my xiaomi Mi Band 2 doesn't work anymore. It finds it in the Bluetooth device list but it can't pair anymore.
PLEASE fix this as fast as possible!
burg3r
Re: Bluetooth LE Support after update
Sat Jan 27, 2018 10:12 am
I have tried anything. Restart, factory reset, wipe, install the Mi Band App fresh, clear Cache,
Sun Jan 28, 2018 1:11 am
Try the workaround posted in this thread ( viewtopic.php?f=191&t=333190&start=70
) and report back if it solves your issue:
0) Update you device to the latest firmware and perform a factory reset after that
1) Disable battery optimization for every bluetooth service as
- Bluetooth MIDI service
- BT Tool
- Bluetooth sharing
and for every app that will need to use bluetooth to transmit data as
- Phone
- Phone services
- Call management
- Phone/Messaging storage
- your music player
- other telephone dialer apps and so on.
- EXPECIALLY THE APP THAT YOU ARE USING FOR YOUR FIT BAND
2) If the previous step doesn't solve your issue, ALSO disable the "Standby intelligent power saving" setting and disable Duraspeed.
3) If the previous step doesn't solve your issue, ALSO set your device into "High performance mode"
