federicus
[USEFUL] 4G APN settings for Argentina - Movistar phone carrier
Fri Jan 26, 2018 1:58 pm
If you have movistar plan in argentina and you see a ! at the right of signal icon, it means your apn is not set right.
To solve it:
Go to AJUSTES - MAS - REDES MOVILES - APN
Open every configuration of apn, look for proxy ip address and just delete it, do the same with port. Go to 3 dot icon and save.
Repeat this process with every configuration.
Restart your phone and volia!USEFUL
Re: 4G not working in argentina movistar -solved-
Fri Jan 26, 2018 3:30 pm
Thanks for you tutorial! It's now highlighted ;)
federicus
Re: [USEFUL] 4G APN settings for Argentina - Movistar phone carrier
Mon Apr 30, 2018 4:47 pm
Great!
