andresfr84
[SOLVED] Camera button not working - 20180124 updated installed
Fri Jan 26, 2018 8:47 am
Hello, I have a new BV8000PRO, bought yesterday, I've installed all the updates and the camera button is not working. Even with a button remapper app it is not recognized. Someone else with this problem?
I've tried long press to open app and short press to take photo, none of then works.
Re: Camera button not working - 20180124 updated installed
Fri Jan 26, 2018 9:56 am
Hi there!
Did your camera button work before the update? If not, this issue may also be related to an hardware fault.
Did you perform a factory reset after the update? If not, perform it and report back.
Can anybody else confirm this issue?
andresfr84
Fri Jan 26, 2018 10:21 am
I don't know if it worked before, the first thing I did was install all the incremental updates, and then start configuring and testing. I'd prefer to not lose all the configuration and apps, is there any test I can run insted of factory reset?
Fri Jan 26, 2018 11:50 am
Considering that:
- You don't know if it worked before
- The button remapper app doesn't see it
- The issue is definitely uncommon
it really looks like an hardware fault.
I reccomend to contact your seller to have your device replaced under warranty. This will be the only solution.
By the way, before doing that, i suggest you to perform a factory reset just as a confirmation.
No other tests can be run.
andresfr84
Re: [SOLVED] Camera button not working - 20180124 updated installed
Fri Jan 26, 2018 12:11 pm
Ok, there is no hurry, so by the moment I'll try:
-Update on my couple phone (same model), this night I can try and give feedback.
-Wait and see if there are anyone with the same situation.
Fri Jan 26, 2018 12:37 pm
Remember to perform a factory reset after each update!
I'll wait for your feedback ;)
andresfr84
Fri Jan 26, 2018 12:41 pm
From the menu o from recovery mode?
jman0
Fri Jan 26, 2018 1:11 pm
Just in case you didn't try or know (sorry if this sounds stupid) in order to launch the camera app with the button, you must long press it, not just a single short press. I'm saying this because when I got the phone I thought it didn't work because of that. I just tried on my phone (updated yesterday to 20180124 firmware) and it works.
Then, if you want to take a photo when the camera app is open, the button only works on stock camera.
andresfr84
Fri Jan 26, 2018 1:14 pm
Yes, I've tried. So, the factory reset should be done from the menu options - backup and recovery - factory reset, or from recovery mode?
Fri Jan 26, 2018 1:33 pm
Both ways will work the same, your choice!
