nkuanhoe
20180104 update details
Thu Jan 25, 2018 3:57 pm
Can admin pls advice more details on this update?
HelloWorld
Re: 20180104 update details
Thu Jan 25, 2018 9:12 pm
Is this Android 7? Great that there is an update! Would like to receive more info before I'll flash this one.
hersche
Thu Jan 25, 2018 11:01 pm
hello,
i've tried it, and it's android 7.
what i translate out of the changelog is:
1. add face-unlock (found it, but not work, may because of bad light)
2. weird translation, something fixed with the screen (about blinking? really weird translation)
i just unchecked userdata and had nothing to restore - seems to work proper in the first 20 minutes ;)
PS: blackview, please update the security-patches too!! ;)
nkuanhoe
Fri Jan 26, 2018 2:53 am
I'm still in Android 6, but Bluetooth not working properly~ was thinking to flash to this. Need more info before proceeding~ thx all
mobosenshi
Fri Jan 26, 2018 5:57 am
hersche wrote:
hello,
I just updated my BV6000 via local update but it shows up as 20170708. What does yours say?
bvbw
Fri Jan 26, 2018 7:33 am
... not enough informations about this update from Blackview ... as usual !!!
HelloWorld
Fri Jan 26, 2018 7:44 am
I think that you need to flash this one using a PC. The procedure is in the sticky post in this forum section.
nkuanhoe
Fri Jan 26, 2018 9:48 am
hersche wrote:
hello,
How is the battery performance? since many comment about previous 7.0 battery issue~
hersche
Fri Jan 26, 2018 10:56 am
Oh, i have to say: i did not do a local update, i do it via SP-Flash-Tools. I don't know if it works via local update.
My build-number contains still v01_20170412
my kernel build is from 2018 now
when i go to system-update, there's something like v01_20170412_20180104-1351
with the build-number, it is a bit confusing (because it's old), but it still applies :)
Batteryperformance looks ok to me. About 25% in the night before, 20% after wakeup.. not better or worse for me, but i not reconized a issue there till now anyway ;)
edit: i don't know if it's by hardware or software/upgrade, but today i had a batterycrash with reloading over hours. also, the preloader (batterysymbol when phone is "off") does not come to battery-percentage - right now i was able the first time to start the system again. the battery was at 3 percent. when the phone was off, only the battery with circle was shown and screen stays enabled (what costs lot of energy which is used to load) - so you may see my idea, why the preloader could be problematic.
the very empty battery could also be a bit of dirt or what do i know, doesn't have to be the firmware in my opinion..
personally, i hope it loads till 100% and works as usual then. i will keep my update and maybe downgrade the preloader only.
someone else expirienced this?
edit 2: ok, it was definently hardware.. what a torture i had now, i opened the phone a few times, but the first time at all..
usb-connector was flickering, i had to bend the inside of bv6000's connector a bit with small zip-ties.
camera-connector was not pressed after opening, so i downgraded and made a factory-reset to test if this is firmware - nope. opening once more was the solution.
so far, the firmware looks ok then. sorry for the misleading intepretations i've wrote.
ps: very nice and structured inside, blackview. everything is accessible and nice to disassembly for fixing, compliment, this is very cool! :)
McSNox
Mon Jan 29, 2018 10:00 am
Will this update be distributed by OTA?
Can not update using a computer
Blackview BV6000 V01_20170708
