khaqanson
[SOLVED] New update 20180124 package error
Thu Jan 25, 2018 4:32 am
When ever i tried to update through OTA , after downloading unziping the archieve results in "archieve failed download again" I have formatted my phone many times , still the same, I rolled back to previous roms but error is still there. Why evrytime this is happening even though i format my phone , install new Roms through flash tool ,the problem is still there!!!!
Re: New update 20180124 package error
Thu Jan 25, 2018 9:46 am
It seems that your dowload gets corrupted....
Can you download the package using another network, just to try?
khaqanson
Thu Jan 25, 2018 11:42 am
I have checked it on many other networks, data plan and even on wifi , every time same result. I have done all the things, flashing ,formatting ...everything but no success :| :shock: :?
Thu Jan 25, 2018 7:06 pm
Flash files are on the way, don't worry ;)
AdvIKAR
Re: [SOLVED] New update 20180124 package error
Sat Jan 27, 2018 6:32 am
Same problems ...
khaqanson
Tue Jan 30, 2018 8:12 am
AdvIKAR wrote:
Same problems ...
Reason Found for package Error
Atlast am succeeded to install 20180124 OTA updates without paackage corrupt Error, what you have to do is :
" Do NOT INSTALL DOWNLOADED PACKAGE AT ONCE"
When download is complete wait for around 5 mins ( minimum 2 mins) and then tap on install now. Hope it will solve the problem as mine is solved by doing so.
Tue Jan 30, 2018 10:19 am
khaqanson wrote:
AdvIKAR wrote:
Same problems ...
Thanks for your precious feedback! ;)
khaqanson
Tue Jan 30, 2018 11:42 am
khaqanson wrote:
AdvIKAR wrote:
Same problems ...
Pleasure is always mine , And thanks for full Rom (20180124) download link.
