[TUTORIAL] How to increase microphone sensivity on BV9000Pro devices
Mon Jan 22, 2018 10:39 pm
Let's see how to increase microphone sensivity on BV9000 Pro devices to fix microphone related issues.
Reminder: if this tutorial helps you to solve microphone issues, post your confirmation and don't edit any other setting (this will help us to set some variables).
If this tutorial doesn't help you, please post further details about it: we'll find out other ways to solve the problem.
1) Dial the number *#9646633# in the dialing interface to enter the EngineerMode.
2) Slide your finger from right to left to get into the Hardware Testing page.
3) Tap "Audio" to enter into the audio settings interface.
4) Tap "Volume", then tap "Voice" in the next interface to enter the microphone gain modification interface.
Image Image
5) Change the "UL Gain" value from 168 to 220.
Image Image
6) Tap "Set" and, after that, "Ok" in the confirmation prompt.
6) Tap "NB", and select "WB" from the dropdown menu.
7) Change the "UL Gain" value from 168 to 220, then tap "Set" and, after that, "Ok" in the confirmation prompt.
8) Reboot your device.
treivax
Re: [TUTORIAL] How to increase microphone sensivity on BV9000Pro devices
Fri Jan 26, 2018 7:52 pm
Merci beaucoup! ;)
thank you very much. ;)
mambo
Mon Jan 29, 2018 12:50 pm
This method helps but it's not perfect. When UL Gain was 168 then some calls was awful and some calls was with clear quality. (15...40% was bad quality). When I increased UL gain to up 220 then awful quality calls are little better but not near good. Now are some calls very noisy but louder and the other people can hear me.
In my opinion is the call quality depends of band what phone using. Seems like UL Gain is some "master gain" and ingrees microphone sensitive in every band together.
Is there any adjustment for every band (900 MHz; 1800MHz...) separeately?
There is low sensitve mic problem problem wiht video and sound recording also!
Cicciosof
Wed Jan 31, 2018 9:17 pm
I have performed the procedure to increase the microphone, it has improved but it still too low
grAwp
Mon Feb 05, 2018 12:31 pm
On BV6000 was MIC transmittion OK (very good quality), but complications arrived on new model BV7000 Pro (bad microphone transfer after gain to maximum), but complications still persist :shock: . Make some new improvment to increase quality of the BV9000 Pro MIC, lot of people will be returning these phones back because of MIC hardware problems :roll:
war_horse
Thu Feb 08, 2018 7:00 pm
it works like a charm, thank you
paulies
Wed Feb 21, 2018 5:00 pm
There is a slight improvement can you go any higher than 220?
Thanks Paul
grAwp
Thu Feb 22, 2018 8:16 am
I dont have this problem on BV9000 model. :o :shock:
paulies
Thu Feb 22, 2018 9:06 am
I have never bought a blackview phone where I have not had a problem but to be fair the BV8000 Pro did have plenty of updates to help fix issues just hope they do the same for the BV9000 Pro
I find when on speakerphone no one can hear me at all and when doing videos, WhatsApp, Skypeit is very very poor is there a solution for this?
Thanks Paul
paulies
Sun Apr 15, 2018 2:05 pm
*Bump*
Oh and don't say factory reset which seems to be your only answer at fixing every phones problem
Thanks Paul
