nsansilva
[SOLVED] Privacy Space
Mon Jan 22, 2018 7:13 pm
I want know if the bv8000pro go have the feature "Privacy Space" like announced on the P6000?
https://twitter.com/Blackview_HK/status ... 4860998656
Thanks,
Natanael dos Santos.
Re: [SOLVED] Privacy Space
Mon Jan 22, 2018 11:38 pm
Yes, it already has a comparable feature.
Just go to Settings -> Security -> Data protection (or something like that... you'll find it just near the "Unknown sources" entry).
Set an entry pattern, confirm it and you'll get into a data protection interface ;)
