khaqanson
[SOLVED] No Whatsapp notifications after 20171227 update!!
Mon Jan 22, 2018 3:56 am
Well!! its quite amazing, at first I installed 20171219 update ,All was working normal except bluetooth turning on automatically.Then I formatted and updated my bv8000 pro to 20171227 and every time when I open my whatsapp then I am able to get all the notifications all together, if phone is on standby mode , no notifications at all .I checked it for a day, and after that i Rolled back to 20171219 Rom. I don't know ,why each Rom of you having some kind of problem?? may be beta testers are not that much good :| :|
Well Lets hope to get better in next update!!!!
ghost82
Re: No Whatsapp notifications after 20171227 update!!
Mon Jan 22, 2018 8:56 am
I think it's the normal behaviour if you don't receive whatsapp notifications when your mobile is in deep sleep mode, unless you don't optimize whatsapp in the battery settings.
Mon Jan 22, 2018 9:57 am
Yeah, you're right.
Just remove the battery optimization setting for Whatsapp and whitelist the app in the background task clear settings and every problem will be solved ;)
khaqanson
Tue Jan 23, 2018 6:07 am
blackview_admin wrote:
Yeah, you're right.
Really??? Coz it was already in white-list , but in network control list. I will see flashing the Rom again:S
BTW it would be my 4th time in a week losing all installed apps coz everytime i have to formate the phone!
Alesonda
Tue Jan 23, 2018 7:53 am
Hi, after last firmware my BV8000 notifications are ko, apps opening are slow, sometimes the phone reboot, to see if I received a sms or a whattsup I have to open the app. It's not possible use the phone in this condition, you have to make a new firmware as soon as possible, or give possibility of install the firmware before the new. It's not possible make a mistake as this. Incredible
Tue Jan 23, 2018 9:38 am
Yeah, you're right.
Network control whitelist IS DIFFERENT from background task clear whitelist! You need the latter!
You should also disable the battery optimization setting for the desired app. Just go to Settings -> Battery -> "3 dots" -> Battery optimization.
No need to flash the rom again ;)
Re: ---
Tue Jan 23, 2018 9:43 am
Please stop posting in wrong threads. Every issue has its own discussion thread, so, please, read it.
For the notification issues you'll find the solution in this thread ;)
