DekyPrimaswargi
[SOLVED] BV8000 Pro often can not be in the charger & Camera is Very Nois
Sun Jan 21, 2018 12:58 pm
Fix Battery can not be in charger & Nois the Camera please ...
in this video link: https://youtu.be/tnuHO8fychQ
Re: BV8000 Pro often can not be in the charger & Camera is Very Nois
Sun Jan 21, 2018 4:27 pm
Hi there!
Please add some details to your problems if you want to be helped properly.
When did you buy your device? Did you update it? What's your firmware version?
