IfeBV
[SOLVED] Screw Rubber for SIM card panel.
Sat Jan 20, 2018 9:38 pm
Hello Admin,
I was reading up older posts and saw where BV8000 pro became faulty when immersed in water because some of the SIM screws did not have a rubber packing.
I have examined mine be can't seem to find any rubber at all on all four screw for the SIM compartment, is it okay to use my phone under water?
Re: Screw Rubber for SIM card panel.
Sun Jan 21, 2018 10:14 am
Hi there!
Don't worry, sim tray water seal is granted by this blue gasket:
No need for o-rings on the sim tray screws. Instead, they are needed for the body torx screws. ;)
