chidkaii
[SOLVED] left button near home button
Sat Jan 20, 2018 6:45 pm
in the left button near home button
when touch it. Is its show menu or recent app?
after I update last firmware. its only show menu and hold its ,then it will show recent app.
In the first day I buy new phone its can touch and show recent app before update.
Re: left button near home button
Sat Jan 20, 2018 9:27 pm
Hi there!
Your "menu" button is working as expected from the latest firmware updates.
Hold it for menu, press it once to show recent apps.
chidkaii
Re: [SOLVED] left button near home button
Sun Jan 21, 2018 5:02 am
now my phone hold is recent app.
and one tounch is show menu.
chidkaii
Sun Jan 21, 2018 6:29 am
now my phone Hold it for recent apps, press it once to show menu.
How am I setting its or not.
Sun Jan 21, 2018 10:32 am
blackview_admin wrote:
Hi there!
Hi there, sorry but i made a typo while writing my last sentence.
I'll explain in detail:
Before the 20171011 update, holding the button led to recent apps list, while pressing it once led to menu.
After the 20171011 update, holding the button led to menu, while pressing it once led to recent apps list.
From the 20171114 update, holding the button led again to recent apps list, while pressing it once led to menu.
So, from the 20171114 update, holding the button to show to recent apps list and pressing it once to show menu is the correct behaviour.
You don't have to worry. Your device behaves as expected. ;)
chidkaii
Sun Jan 21, 2018 2:03 pm
can you add setting to switch its.
I want to press one touch to recent app ,please.
ghost82
Sun Jan 21, 2018 2:50 pm
I suggest to search for apps to do it, search for remap keys, or similar.
chidkaii
Sun Jan 21, 2018 7:08 pm
:oops: :roll: can you suggest me.
i try many app cannot rewite action of menu button.
i think it is a bug because many app dont know menu button of blackview.
and functuon of recent app is double tab to switch app but if hold to recent app its cant double hold menu to do this function.
