kadar
Root
Fri Jan 19, 2018 1:15 pm
How can I root the device (important)?
Re: Root
Thu Apr 12, 2018 5:56 pm
Rooting can't be officially supported, for obivous reasons. I'm sorry.
jean_bruder
Re: Root
Fri Feb 15, 2019 2:59 pm
Dear all,
I'm very interested too in rooting my phone for some simple reasons, like install some ads-block software (https://f-droid.org/fr/packages/org.adaway/), some geek tools (https://play.google.com/store/apps/deta ... drivedroid) ...
Right now, I succedeed in installing the last TWRP recovery image, but after booting into recovery mode, and because the phone is crypted by design, I cannot mount the partition in order to install SuperSU ...
I would like to be abble to use the phone I purchased in the way I want, and rooting the phone seems to be just a normal step !
Many thanks in advance for you support ...
Regards,
Jean
