Problem is that association is not possible due to "not corresponding codes"...this is meaning that the code generated by the car and the one generated by the phone are different!
It seems that when I launch the system, a window with the right code appears on the phone but disappears instantly and a new one is generated a few minutes later but not corresponding to the car's one...
Is this a known problem? Coming from the car? Is there a solution?
Except this "problem", the phone is working perfectly
Many thanks!
Jack
